I purchased Autocad LT 2005 and then Autocad LT 2008. The latter was upgraded to Autocad LT 2010 by download (no hard copy). i am trying to install the 2008 version again (after a crash) but the serial number and license key do not work. I do not know the serial number and license key for the 2010 version. Any suggestions would be helpful.
Solved by jessica.t. Go to Solution.
Hello and welcome to the Community!
I tried researching your licenses by your email address but found that you only have an AutoCAD LT 2008 and AutoCAD LT 2011 associated to you. To locate your AutoCAD LT 2010 serial number please contact our Activation and Registration department:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus.
4. Select “I Still Need Help” if you need personal assistance.
If you have any other questions or concerns please respond to this post. Thank you!
Thank you, Jessica.
Since the most recent upgrade was handled online, it could have been LT 2011. Would it be possible to activate that license?
cwcoon
Yes it would be! You can download the AutoCAD LT 2011 software directly from our Virtual Agent and then activate with the corresponding licensing information which I will send to you in a private message. If you have anymore questions just let us know. Thanks!
