Installation & Licensing
Active Member
andy.beckett123
Message 1 of 6 (523 Views)
Re-Installation Problems
523 Views, 5 Replies
05-26-2011 02:58 AM
I uninstalled Autodesk Inventor 2011 a while ago (I have Windows 7), and I have been trying to re-install it in the last couple of days.
I downloaded the zip files, used the Self-Ectracting archive, then got onto the installation wizard.
When I get to the "Select the Products to Install" page, Autodesk Inventor 2011, AutoCAD Mechanical 2011, Autodesk Vault (Client) and Autodesk Design Review 2011 are greyed-out and the boxes cannot be checked. I can only install Content Centre Libraries and Autodesk Material Library 2011 Medium Image Library.
Attached screenshot below.
Does anyone know how I can re-install Inventor 2011?
Thanks.
TravisNave
Message 2 of 6 (485 Views)
Re: Re-Installation Problems
05-26-2011 08:34 AM in reply to: andy.beckett123
Your computer still thinks Inventor is installed.
Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
You should try the clean-uninstall first as you have Windows 7.  Please use the MSICUU2 at your own risk.
Active Member
andy.beckett123
Message 3 of 6 (476 Views)
05-26-2011 09:38 AM in reply to: andy.beckett123
Thanks, TravisNave, I'll try your suggestions.
Active Member
andy.beckett123
Message 4 of 6 (440 Views)
05-27-2011 12:59 PM in reply to: andy.beckett123
OK, that fixed my original problem, but now I have another:
I get an error message halfway through installation:
Error 1402. Could not open key.
 Full error message screenshot attached
Can anything be done?
Thanks again.
Active Member
andy.beckett123
Message 5 of 6 (417 Views)
05-28-2011 01:52 PM in reply to: andy.beckett123
Bump
TravisNave
Message 6 of 6 (381 Views)
06-01-2011 09:41 AM in reply to: andy.beckett123
