Solved by kostery. Go to Solution.
Solved by Silvia.Menon. Go to Solution.
your AutoCAD LT 2011 CD should include the full program, so no need to install the previous version. You can just install LT 2011 and activate it with the same serial number and product key (but your request code and activation code will be different on the new machine).
More information about the activation process can be found here:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=3970195
Please also be aware that depending on whether the upgraded license is under Subscription or not, you may not be entitled to keep using the previous version after you upgraded the license. Please refer to your license agreement for details.
Regards
Silvia
Silvia Menon
Support Specialist
Product Support
Autodesk, Inc.
http://www.autodesk.com/autocad-support
Dear Sylvia,
Thanks for your swift response. I shall follow your instructions and keep you posted on the results.
Dear Silvia,
I can confirm the installation and activation of my AutoCad 2011 was successful with out any difficulties.
Thanks again for your kind and swift support.
Rgds Yvon
