I downloaded the TruView. but it's not opening the dwf files. it's even saying the folder is empty when I try to click on a file of my prints. I'm confused. please help
I've attached the type of file I'm trying to open.
Cassie
Solved by philip.s. Go to Solution.
Hi Cassie,
Per the following, Design Review is required for opening DWF files.
http://www.autodesk.com/products/dwg/viewers
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
