Installation & Licensing
Member
chopley
Message 1 of 4 (355 Views)
rdesktop from linux machine to Windows Server 2003 x64
355 Views, 3 Replies
09-13-2011 09:20 AM
I am running Autodesk Inventor 2010 (Build 211m Release 10) on a Windows Server 2003 (ercsim2) machine.
The software works perfectly when I am using the machine locally, however I would like to run the software remotely, using a remote desktop connection from my linux box (aslx10 running Ubuntu 10.04) in a different room in the building. This is how I run all the windows software that I require.
When I login to ercsim2 using rdesktop (from aslx4) and attempt to run Autodesk Inventor, I get an hourglass icon for a few seconds after which it seems that Windows abandons the process. I use the following rdesktop options:
$ rdesktop -g 1900x1100 ercsim2.physics.ox.ac.uk
I would imagine this may have something to do with graphics issues? Unfortunately I am not particularly well versed in identifying these bugs in Windows as most of my time is spent on a linux box.
It would be possible to simply walk across to the Autodesk Inventor machine when I need to use it, however I am able to run every other piece of Windows software that I need using remote desktop, and would like to continue this.
I am able to run Autodesk Inventor Design Assistant, Autodesk Inventor View, but not Autodesk Inventor
Are there any ideas in how to get this working?
TravisNave
Message 2 of 4 (347 Views)
Re: rdesktop from linux machine to Windows Server 2003 x64
09-13-2011 10:48 AM in reply to: chopley
No.  This setup is in violation of your End User License Agreement and this action is not permitted by Autodesk.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Member
chopley
Message 3 of 4 (336 Views)
09-14-2011 02:02 AM in reply to: TravisNave
Thanks for your reply:
I was under the impression that provided the access was made from within the same physical site this was alright-
There is another post (http://forums.autodesk.com/t5/Autodesk-Inventor/assembly-problems/m-p/2675239/highlight/true#M373274) which references using rdesktop to do this-
Please could someone clarify whether this is indeed against the EULA?If not then the question remains whether it is possible to access Inventor from rdesktop.
Member
chopley
Message 4 of 4 (334 Views)
09-14-2011 02:08 AM in reply to: chopley
Hi:
I see a similar previous post by yourself here as well
http://forums.autodesk.com/t5/Installation-Licensing/Autocad-2012-clustering/m-p/3156184#M37689
This states that RDP is not permitted by the EULA.
As such I will close the post as answered.
Thanks for your help.
