I am trying to print my document, but the not all the raster images are showing up. I have tried changing the image quality, raster percent, raster threshold, and mp plot transparency. None of these have helped. I also tried changing the quality via the printer.
I have tried converting the image files to pdf to no avail.
I have also tried reducing the file size using the purge command. Still didn't work.
I am currently trying to reproduce the raster images to cover more area per image. This, however, has reduced the image quality to where it looks horrible.
You might try this:
Open the Printer’s Properties Option>select the Graphics + sign>select Raster Graphics> set the “Raster\Rendered Viewport” slide bar to 2nd setting from Left and the “OLE” slide bar to 2nd from Left. Some times the raster is too big for the printer to handle at the "Best" setting.
