For security reasons, please do not link to pictures that are outside of the forum. There is no way to verify if the link is safe to click.
Post your screencap and any installation log files here.
If you need instructions, you can find them here:
Thanks.
Thanks for the explanation.
This error is causes almost always by your anti-virus program. You might temporarily disable it and try to install your Autodesk product again.
Good Luck!
And you aren't running BitDefender or any other malware program at all? Is this XP a fresh install?
If so, open your Registry and make sure that this key exists:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce
If it does not, create the new RunOnce key. Then try again.
Beyond that, make sure that you aren't using any encryption on your data and that your MSI Windows Installer is updated to the absolute latest version for Windows XP. Since Windows XP is retired, you might find that difficult to do.
Now you are on Windows 7 and it still won't install? Is your media still good?
Hey!
I'm getting the same error on windows 10. Nothing encrypted, every antivirus and malware protection off. and the file is in the registry.
