Hi!
I get the following message when trying to activate my AutoCAD for Mac: "The serial number you entered is not valid. Try again. (1)". The serial number IS correct, but it just doesn't work. What can I do?
AutoCAD for Mac 2016, i tried both typing and copy-pasting. And the link does not help me, I have seen the page but there was nothing helpful there.
If I remember correctly, one user mentioned this before, and he is from Spain.
Could you please try using some other language input source, for example, using English > U.S. And try reboot the machine, and try again.
If it still does not work, please send me the serial number and product key that you are using by email. I need to check whether it is valid.
My email:
wei.ma@autodesk.com
Wei
Hello @Anonymous,
Sorry to hear your serial number is giving you this error. Please try the following steps to see if the issue can be resolved.
- Choose Apple menu > System Preferences, click Keyboard, then click Input Sources > Click Add, search for a language or input source, then select one or more input sources > Click Add.
- Type the Serial Number (do not copy/paste it)
- Make sure you are using the appreciate product serial number & product key you should receive green check marks
Please keep us posted on the progress. Thank you.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Hello @Anonymous,
I wanted to follow up with you, I hope you were able to resolve the issue.
If so, please select a response that resolved the issue and click "Accept As Solution" button to help others in the community.
Thank you.
Natasha
Helpful Links:
