Installation & Licensing
New Member
mdomingo16
Message 1 of 9 (28,660 Views)
"The security system is not functioning or is improperly installed"
28660 Views, 8 Replies
11-10-2011 02:26 PM
Whenever I open up my autocad program a message shows up saying "The security system (softlock license manager) is no functioning or is improperly installed". I tried uninstalling it and installing it again but that doesn't work. So I sent an email with the problem and they told me to download a service package. I downloaded it and the problem is stil there. Does anyone know what to do?
philip.s
Message 2 of 9 (28,648 Views)
Re: "The security system is not functioning or is improperly installed&quot
11-10-2011 03:25 PM in reply to: mdomingo16
Hi sk8ter_marina,
Looking at other posts it looks to be associated with a permissions issue. Please check out some of these other threads and let me know if they resolve the issue.
http://forums.autodesk.com/t5/Installation-Licensing/softlock-license-manger-error-message/m-p/30046...
http://forums.autodesk.com/t5/AutoCAD-2012/softlock-license-manager-is-not-functioning-or-is-imprope...
Philip Schmelzer
New Member
mdomingo16
Message 3 of 9 (28,641 Views)
11-10-2011 03:32 PM in reply to: philip.s
I'm not quite sure what exactly I am supposed to do. It's saying to give everyone full control permissions. how do i do that?
DarrenP
Message 4 of 9 (28,627 Views)
11-11-2011 07:06 AM in reply to: mdomingo16
do you have an I.T person you can talk to?
its microsoft windows permissions
New Member
ericsho96
Message 5 of 9 (25,666 Views)
12-25-2012 10:11 PM in reply to: mdomingo16
Hi sk8ter_marina,
I think you should try this. It work for me.
First, go to start menu, then type msconfig in the search box. After that, go to service. Make sure you hide all Microsoft Services. From that, you can find FLEXnet Licensing Services. If the FLLEXnet Licensing Services has been untick and disable, tick again and apply. Close System Configuration and restart. Once restart. you can use AutoCAD.
I accident disable FLEXnet Licensing Services. That's why i cannot use the AutoCAD.
Here's the picture I want to share.
New Member
freepark
Message 6 of 9 (25,118 Views)
01-27-2013 07:38 AM in reply to: mdomingo16
o! senks! its real work))
New Member
morgosmacko
Message 7 of 9 (20,964 Views)
06-19-2013 07:40 AM in reply to: ericsho96
Unfortunately starting the Flexnet service does not solved my problem. The key was, I think, that AutoCAD for some reason was set to standalone licencing instead of network licensing. The solution for this problem I found in another forum here, where "gwc" user wrote the followings:
"What finally did work was this: After reviewing the "C:\ProgramData\Autodesk\Adlm\CIV3D2012ENUAdlm.log" I decided the problem must be the ProductInformation.pit file in the same folder. I replaced this file with one from a computer with a working install and the prolblem was fixed."
My problem was also fixed when I replaced the "C:\ProgramData\Autodesk\Adlm\productinformation.pit" file with another one from a computer running Autocad problem free.
New Member
bhuraaamer
Message 8 of 9 (18,689 Views)
08-19-2013 06:26 PM in reply to: mdomingo16
thanx a lot .....i used that and it worked for me....
prem
Message 9 of 9 (14,992 Views)
10-30-2013 06:46 AM in reply to: bhuraaamer
i am facing the same problems at one of our customer locations.
none of the methods mentioned in the support and dicussion groups are working out
Any solutions!!
Prem
Windows 7 64 Bit
16 Gigs of RAM
Intel I7
Nvdia Quadro 3000M
