I'm trying to install the trial version of Revit 2014 and keep getting this error. It seems to be related to Microsoft Visual C++. Based on other messages on here I removed all versions of C++, multiple 2005, 2008 and 2010 and restarted the computer, but I'm still getting the same error.
Installation log file attached.
Please help!
Hello and welcome to the forum,
You are correct in identifying Microsoft visual C++ as the point of failure. It looks like it can't install Visual C++ 2005. Can you try manually running the installer it's failing on in the below location? This should load only the Visual C++ install and will give a more helpful error message if it fails.
C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe
Also, while trying to figure out this issue, I needed to use the software for a class so I was using the free online trial. Today, when I tried to open a project a window popped up saying "Synchronizing User Data" In the window it says "your data is being synced with Autodesk 360 Cloud, and it says it synchronizing, but the little green bar keeps filling up and starting over and nothing happens. So now I'm not able to use Revit in any form...
I need help, desperately, I need someone over my shoulder (or on the phone) telling me what to do step-by-step, I hate that this is not an option with Autodesk, I'm so frustrated!
Since this is a issue with a Microsoft Product (Visual C++) I took a look at the solutions on the microsoft site but unfortunately it looks like it took a format and re-install of the OS to get around this error with Visual C++ 2005 for some people but there were a few other solutions posted. You may want to take a look at the thread linked below for some ideas.
