Installation & Licensing
amandaer
Message 1 of 30 (11,289 Views)
"Setup initialization failed"-message pop up when I try to install any product!
11289 Views, 29 Replies
09-18-2012 08:04 PM
I have a new Windows 7 64bit laptop which I am trying to get the student license for AutoCAD, Revit and 3dsMax installed on. I have been trying for weeks, but after downloading the installation file and pushing the install button I constantly get the error: "Setup initialization failed. Connection has expired. Please reconnect to site."
It seems like Autodesk can't recognize that I am in fact logged on, and I have been trying to log off- log on to try to solve it but I keep on getting the same error.
The internet is not the problem, my friend managed to install AutoCAD on his computer on the same line.
Please help, what can I do?
Grateful for any advice,
Amanda
It's all dependent on the download method / that looks like it would have resulted from Install Now. If you choose the Browser Download option, you would just be moving an .exe file from one machine to another which doesn't require additional communication with the initial machine.
Product Support
david.lau
Message 2 of 30 (11,238 Views)
Re: "Setup initialization failed"-message pop up when I try to install
09-20-2012 06:37 AM in reply to: amandaer
Are you able to download the software as a 'browser" download?
David Lau
amandaer
Message 3 of 30 (11,232 Views)
09-20-2012 08:19 AM in reply to: amandaer
Yup I can download it, but when pressing install I get the error code.. I wanted to try it again now, but there seems so be a problem with me signing in at http://students.autodesk.com/?nd=login, I only get an error code when trying to log on. Logging on here was not a problem though.. Strange!
Thanks!
philip.s
Message 4 of 30 (11,226 Views)
09-20-2012 09:09 AM in reply to: amandaer
Hi amandaer
I just reset your Education Community password (of which I'll be sending you the details via email) and verified access. Please delete your temporary internet files, clear the cache etc. and try logging in again. If you're still receiving the error you may want to consider switching browsers.
Please let us know if the browser download option resolves your issue.
Philip Schmelzer
amandaer
Message 5 of 30 (11,207 Views)
09-21-2012 11:10 AM in reply to: amandaer
Tried to install Revit by browser downloading, but half way through the process I got this error instead: See attached image.
Something definitively strange is going on.
Amanda
amandaer
Message 6 of 30 (11,204 Views)
09-21-2012 11:13 AM in reply to: amandaer
The same thing happened to me trying to install 3dsMAX, see image.
philip.s
Message 7 of 30 (11,200 Views)
09-21-2012 11:22 AM in reply to: amandaer
Hi amandaer,
CRC errors may be avoided by using a different web browser, an alternate download method (maybe try the Download Now option), or by temporarily disabling all anti virus software and firewalls as they may be prematurely ending the download.
Philip Schmelzer
amandaer
Message 8 of 30 (11,197 Views)
09-21-2012 11:38 AM in reply to: philip.s
Thanks Philip,
Ok, so now I have tried changing to the Mozilla browser and tried to "install now” that resulted in the same primary error popping up.. Then I also tried doing it while my firewall and virus program was totally switched of, that did not work either. Then I tried installing the browser downloaded over night with the protection switched of, but the same problems I got recently occurred. Nothing is working..
philip.s
Message 9 of 30 (11,195 Views)
09-21-2012 11:42 AM in reply to: amandaer
You're welcome amandaerDid you try the Download Now option?
Philip Schmelzer
amandaer
Message 10 of 30 (11,191 Views)
09-21-2012 11:50 AM in reply to: philip.s
Yup, both with and without the computer protection on.. I get the same error as I did the first times. See image
