Installation & Licensing
"Revit Could Not Load..." Error
13 REPLIES 13
Message 1 of 14
8861 Views, 13 Replies
I just installed the Revit Architecture 2012 upgrade and come up with the following error when I try to start the program:
! Revit could not load C:\PROGRAM FILES\AUTODESK\REVIT ARCHITECTURE 2012\PROGRAM\CONCEPTUALENERGYANALYSISDB.DLL
The file appears to exist at that location.
I'm running Windows 7 on a capable computer.  Any thoughts on what I can do to fix this problem would be appreciated.
Thanks.
13 REPLIES 13
Message 2 of 14
DarrenP
32 bit or  64 bt?
DarrenP
Message 3 of 14
64 bit hardware.  The download file was "Autodesk_Revit_Architecture_2012_English_Win_32-64bit" but I don't recall having an option presented to choose when I installed (twice).
Does this information help?  Thanks!
Message 4 of 14
DarrenP
try to do a repair installation
DarrenP
Message 5 of 14
DarrenP
in reply to: DarrenP
here is mine
try copying it to the same location
DarrenP
Message 6 of 14
DarrenP
if this doesn't work try doing a repair installation
DarrenP
Message 7 of 14
Thanks... I'm trying the "repair Installation" .  If that doesn't work, I'll try saving your dll over top of it.  Thanks for your help!
Message 8 of 14
What was the final solution here?  Did the reinstall work or did you find a different solution?
I am plagued by the same issue - reinstall does not work.
Thanks;
Nick
Message 9 of 14
DannyHubbard
This could be related to a corrupt .Net 4 framework install.
Try going to Control Panel and Uninstall a Program, uninstall everything related to Microsoft .Net 4 Framework, may be serveral things.
Then reboot and reinstall .Net 4 Framework from the Microsoft site, http://www.microsoft.com/downloads/en/details.aspx?displaylang=en&FamilyID=0a391abd-25c1-4fc0-919f-b...
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 10 of 14
Reinstalling the .net framework solved the problem.
For other who experience this issue, I was not able to uninstall the .net Framework.  Downloading the updated software from the link above and installing over the exsting fixed the problem.  It appears that my own installation had a missing or damaged "Client" which prevented the .net framework from working properly.  I have no idea what any of this means or why it was borken, but the reinstall/repair fixed the issue with running Revit 2012.
Thank you to everyone for the assistance.
Message 11 of 14
Hello I'm also having the same problem as renovatedsm.
Running W7 on a capable machine.
I tried to follow the above solutions however I realised I dont have the .NET 4 Framework Client Profile. When I try to install it (both through windows updater and manually from the website) it failes with the error titled "Generic Trust Issue".
Can anyone provide any thoughts/guidance on how to overcome this issue??
My student copy of Revit Architure 2011 just expired and I really need 2012 to work for my final assignment!!!
Message 12 of 14
liuming_8912
I get this kind  problme,I reinstall the Arc(2011-32) and Str(2011-32), but both of the program can't work .When I click it ,it  turn out a messagebox "Revit could not load RebarDB.dll" as follow)5F%HY@0R@%}9]{~K_IKKER.jpg,I try all sulations above( overwrite the XX.dll ; install network 4.0),but none of them work.Hope someone can help me .Think you
Message 13 of 14
I have reinstall netframework 4.0 and it works 🙂
Message 14 of 14
mikmuh2011
hi. i have revit building design premium 2013 and when i try to open a drawing, it gives this error. yesterday there was no problem, now it dosn't work. i checked other system downloads but there isn't any today.
so i need help
thanks
Administrator Productivity
