HI,
When I log into autodesk student page it leads me straight to the reaffirmation process.
After entering all information corrently and clicking the box to agree to T&C's and error message comes up saying "You must agree to the terms and conditions to continue". The box is definitely check and all other data correct.
What is going on?
Solved by philip.s. Go to Solution.
Hi damonbrom,
I apologize for the inconvenience, but the only work around at this moment for the reaffirmation error / issue within the Education Community is to register with a different email address.
Please let me know if you have any additional questions, or accept this post as a solution if it fully resolves your inquiry.
Hi Damon,
As there is no permanent fix for the reaffirmation issue at this moment, the only workaround is to register with a different email address as mentioned above. Were you able to try that / are you still having issues?
