Installation & Licensing
"License Unavailable. Autodesk Revit Architecture 2012 is in View mode."
1 REPLY 1
ivie5982
3257 Views, 1 Reply
Ok, So I did a clean install of Revit after I removed all my Autodesk programs and files in an attempt to resolve a program crash with AutoCAD 2012 (never resolved).  Upon installation I get the following
"Autodesk Revit Architecture 2012 Build: 20110309_2315(x64)
License unavailable.  Autodesk Revit...is in viewer mode."
I've contacted Autodesk who has registered my serial numbers, and now just needs a request code to activate the license.  My problem is I cannot  get to the "Product License Information" in order to get to the request code  Does anyone have any ideas or am I looking at a full system re-format?
Thank you,
System:
Windows 7 Professional N; service Pack 1 -64 bit OS
INtel -i7-2700K
16 GB Bram
NVIDIA GeForce GTX 560 Ti -2GB
1 REPLY 1
TravisNave
in reply to: ivie5982
Try manually deleting the licensing and see if it will ask for activation.  Remove the following files:
%programdata%\flexnet\adsk*.data
If you haven't already added SP1, do that as well.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
