why AutoCAD Mechanical 2010 license management utility has stopped working ? can anyone help?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=12544120&id=13498182&siteID=123112 this link i already test but does not work for me......
using this site http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617 to remove all Autodesk software products then reinstall but does not work for me ,keep showing this message "license management utility has stopped working‘
Please try the behavior in the disgnostics mode.
http://usa.autodesk.com/getdoc/id=TS1054234
If it works it could be one of the other components (antivirus,antispyware etc.) blocking this
you can also try to add lmu.exe within DEP (if enabled)
http://support.microsoft.com/kb/875352
I had this exact same issue and thought it was an Application Compatibility issue between AutoCAD 2010 and Windows 8.x. After fidling with acad.exe & lmu.exe Compatibility settings unsuccessfully, I think I found that the root cause of my issues were that the FLEXnet license/log files in C:\ProgramData\FLEXnet got corrupted (eg: adskflex_*_tsf.data & adskflex_*_event.log).
Here's what I did:
