Installation & Licensing
"license management utility has stopped working‘
2 REPLIES 2
6863 Views, 2 Replies
2253iD1D14E013A0E3929
why AutoCAD Mechanical 2010  license management utility has stopped working ?  can anyone help?
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=12544120&id=13498182&siteID=123112  this link i already test but does not work for me......
using this site http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617  to remove all    Autodesk software products  then reinstall but  does not work for me ,keep showing this message "license management utility has stopped working‘
2 REPLIES 2
hashim.mundol
Please try the behavior in the disgnostics mode.
http://usa.autodesk.com/getdoc/id=TS1054234
If it works it could be one of the other components (antivirus,antispyware etc.) blocking this
you can also try to add lmu.exe within DEP (if enabled)
http://support.microsoft.com/kb/875352
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
I had this exact same issue and thought it was an Application Compatibility issue between AutoCAD 2010 and Windows 8.x.  After fidling with acad.exe & lmu.exe Compatibility settings unsuccessfully, I think I found that the root cause of my issues were that the FLEXnet license/log files in C:\ProgramData\FLEXnet got corrupted (eg: adskflex_*_tsf.data & adskflex_*_event.log).
Here's what I did:
  1. Recorded Request Code in Activation Window.
  2. Verified that AutoCAD 2010 (acad.exe) was closed (and if it wasn't because it was hung/unresponsive, I ended the Task from Task Manager)
  3. Verified that License Management Utility (LMU.exe) was closed (and if it wasn't because it was hung/unresponsive, I ended the Task from Task Manager)
  4. Opened Windows Explorer and navigated top C:\ProgramData\FLEXnet
  5. Renamed adskflex_*_tsf.data & adskflex_*_event.log to adskflex_*_tsf.data.old & adskflex_*_event.log.old, respectively (in my case, from adskflex_00691b00_tsf.data & adskflex_00691b00_event.log to adskflex_00691b00_tsf.data.old & adskflex_00691b00_event.log.old)
  6. Launched AutoCAD 2010
  7. Followed Activation Prompts
  8. Verified that the Request Cold hadn't changed (if it had, you'll have to request a New Activation Code from Support, as Network Activation seems to be disabled for this "old" version)
  9. Pasted in Activation Code
  10. Activation Succeeded.  On with my day!
Administrator Productivity
