3Ds Max 2013 win64 "Installation complete. Some products failed to install"
I was given this log:
2012/11/18:13:32:03 Hazem HAZEMMD === Setup started on HAZEMMD by Hazem ===
2012/11/18:13:32:03 Hazem HAZEMMD Launch
2012/11/18:13:32:08 Hazem HAZEMMD === Setup ended ===
2012/11/18:13:32:06 Hazem HAZEMMD === Setup started on HAZEMMD by Hazem ===
2012/11/18:13:32:06 Hazem HAZEMMD Launch
2012/11/18:13:32:08 Hazem HAZEMMD PageOpen LaunchDialog
2012/11/18:13:32:55 Hazem HAZEMMD PageOpen LicenseDialog
2012/11/18:13:33:09 Hazem HAZEMMD PageOpen ProductInfoDialog
2012/11/18:13:33:29 Hazem HAZEMMD PageOpen ProductSelectionDialog2
2012/11/18:13:33:40 Hazem HAZEMMD PageOpen FullProgressDialog
2012/11/18:13:33:40 Hazem HAZEMMD Installing DirectX® Runtime: C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/18:13:34:55 Hazem HAZEMMD Install DirectX® Runtime Succeeded
2012/11/18:13:34:55 Hazem HAZEMMD Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:13:35:23 Hazem HAZEMMD Install Autodesk Material Library 2013 Succeeded
2012/11/18:13:35:23 Hazem HAZEMMD Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:13:35:54 Hazem HAZEMMD Install Autodesk Material Library 2013 - Base Image Library Succeeded
2012/11/18:13:35:54 Hazem HAZEMMD Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:13:37:19 Hazem HAZEMMD Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/11/18:13:37:20 Hazem HAZEMMD Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\HAZEM~1.HAZ\AppData\Local\Temp\_AI4BF7.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:13:38:26 Hazem HAZEMMD Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2012/11/18:13:38:42 Hazem HAZEMMD Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/11/18:13:38:59 Hazem HAZEMMD Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2012/11/18:13:39:22 Hazem HAZEMMD Rollback Autodesk Material Library 2013 Succeeded
2012/11/18:13:39:22 Hazem HAZEMMD Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/11/18:13:39:23 Hazem HAZEMMD PageOpen InstallCompleteDialog
2012/11/18:13:41:23 Hazem HAZEMMD === Setup ended ===
2012/11/18:18:00:31 Hazem HAZEMMD === Setup started on HAZEMMD by Hazem ===
2012/11/18:18:00:31 Hazem HAZEMMD Launch
2012/11/18:18:00:40 Hazem HAZEMMD === Setup ended ===
2012/11/18:18:00:37 Hazem HAZEMMD === Setup started on HAZEMMD by Hazem ===
2012/11/18:18:00:37 Hazem HAZEMMD Launch
2012/11/18:18:00:40 Hazem HAZEMMD PageOpen LaunchDialog
2012/11/18:18:00:43 Hazem HAZEMMD PageOpen LicenseDialog
2012/11/18:18:00:46 Hazem HAZEMMD PageOpen ProductInfoDialog
2012/11/18:18:01:18 Hazem HAZEMMD PageOpen ProductSelectionDialog2
2012/11/18:18:01:24 Hazem HAZEMMD PageOpen FullProgressDialog
2012/11/18:18:01:24 Hazem HAZEMMD Installing DirectX® Runtime: C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/18:18:03:05 Hazem HAZEMMD Install DirectX® Runtime Succeeded
2012/11/18:18:03:05 Hazem HAZEMMD Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:18:03:44 Hazem HAZEMMD Install Autodesk Material Library 2013 Succeeded
2012/11/18:18:03:44 Hazem HAZEMMD Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:18:04:07 Hazem HAZEMMD Install Autodesk Material Library 2013 - Base Image Library Succeeded
2012/11/18:18:04:07 Hazem HAZEMMD Installing Autodesk Material Library 2013 - Medium Resolution Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:18:05:06 Hazem HAZEMMD Install Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/11/18:18:05:07 Hazem HAZEMMD Installing Autodesk® 3ds Max 2013: TRANSFORMS="C:\Users\HAZEM~1.HAZ\AppData\Local\Temp\_AI1DDC.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Users\Hazem.HazemMD\Desktop\AUTODESK 3DSMAX V2013 WIN64\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:18:14:28 Hazem HAZEMMD Install Autodesk® 3ds Max 2013 Failed Installation aborted, Result=1603
2012/11/18:18:14:46 Hazem HAZEMMD Rollback Autodesk Material Library 2013 - Medium Resolution Library Succeeded
2012/11/18:18:15:05 Hazem HAZEMMD Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2012/11/18:18:15:32 Hazem HAZEMMD Rollback Autodesk Material Library 2013 Succeeded
2012/11/18:18:15:32 Hazem HAZEMMD Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
I have the same problem!
2012/11/18:19:17:32 CHENG LIN LEE CHENGLINLEE-PC === Setup started on CHENGLINLEE-PC by CHENG LIN LEE ===
2012/11/18:19:17:32 CHENG LIN LEE CHENGLINLEE-PC Launch
2012/11/18:19:17:32 CHENG LIN LEE CHENGLINLEE-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/Autodesk_Revit_2013_English_Win_32_64bit_w..." /SN 900-32861748 /PK 829E1 /student /skipEULA /akamai /auth /sid
2012/11/18:19:21:57 CHENG LIN LEE CHENGLINLEE-PC === Setup ended ===
2012/11/18:19:17:33 CHENG LIN LEE CHENGLINLEE-PC === Setup started on CHENGLINLEE-PC by CHENG LIN LEE ===
2012/11/18:19:17:33 CHENG LIN LEE CHENGLINLEE-PC Launch
2012/11/18:19:17:55 CHENG LIN LEE CHENGLINLEE-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2012/11/18:19:21:56 CHENG LIN LEE CHENGLINLEE-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2012/11/18:19:21:57 CHENG LIN LEE CHENGLINLEE-PC PageOpen LaunchDialog
2012/11/18:19:51:20 CHENG LIN LEE CHENGLINLEE-PC PageOpen LicenseDialog
2012/11/18:19:51:20 CHENG LIN LEE CHENGLINLEE-PC PageOpen ProductInfoDialog
2012/11/18:19:51:20 CHENG LIN LEE CHENGLINLEE-PC PageOpen ProductSelectionDialog2
2012/11/18:19:52:03 CHENG LIN LEE CHENGLINLEE-PC PageOpen FullProgressDialog
2012/11/18:19:52:18 CHENG LIN LEE CHENGLINLEE-PC Download Play VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR...
2012/11/18:19:53:43 CHENG LIN LEE CHENGLINLEE-PC Download Complete VCREDIST2005X86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/VCR...
2012/11/18:19:53:43 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\CHENGL~1\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/18:19:53:49 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2012/11/18:19:53:58 CHENG LIN LEE CHENGLINLEE-PC Download Play KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:54:04 CHENG LIN LEE CHENGLINLEE-PC Download Complete KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:54:04 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:19:54:06 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2012/11/18:19:54:15 CHENG LIN LEE CHENGLINLEE-PC Download Play KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:57:03 CHENG LIN LEE CHENGLINLEE-PC Download Complete KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:57:03 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:19:57:08 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2012/11/18:19:57:17 CHENG LIN LEE CHENGLINLEE-PC Download Play KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:58:02 CHENG LIN LEE CHENGLINLEE-PC Download Complete KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:58:02 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:19:58:05 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2012/11/18:19:58:13 CHENG LIN LEE CHENGLINLEE-PC Download Play KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:58:24 CHENG LIN LEE CHENGLINLEE-PC Download Complete KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:58:24 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:19:58:27 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2012/11/18:19:58:35 CHENG LIN LEE CHENGLINLEE-PC Download Play KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:58:47 CHENG LIN LEE CHENGLINLEE-PC Download Complete KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:19:58:47 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:19:58:48 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2012/11/18:19:58:49 CHENG LIN LEE CHENGLINLEE-PC Download Play KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:20:00:14 CHENG LIN LEE CHENGLINLEE-PC Download Complete KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:20:00:14 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:20:00:19 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2012/11/18:20:00:29 CHENG LIN LEE CHENGLINLEE-PC Download Play KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:20:01:37 CHENG LIN LEE CHENGLINLEE-PC Download Complete KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:20:01:37 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:20:01:41 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2012/11/18:20:01:50 CHENG LIN LEE CHENGLINLEE-PC Download Play KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:20:01:56 CHENG LIN LEE CHENGLINLEE-PC Download Complete KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/KB9...
2012/11/18:20:01:56 CHENG LIN LEE CHENGLINLEE-PC Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:20:01:59 CHENG LIN LEE CHENGLINLEE-PC Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2012/11/18:20:02:07 CHENG LIN LEE CHENGLINLEE-PC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR...
2012/11/18:20:17:35 CHENG LIN LEE CHENGLINLEE-PC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR...
2012/11/18:20:17:35 CHENG LIN LEE CHENGLINLEE-PC Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/18:20:18:41 CHENG LIN LEE CHENGLINLEE-PC Install DirectX® Runtime Succeeded
2012/11/18:20:18:51 CHENG LIN LEE CHENGLINLEE-PC Download Play FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far...
2012/11/18:20:21:49 CHENG LIN LEE CHENGLINLEE-PC Download Complete FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far...
2012/11/18:20:21:49 CHENG LIN LEE CHENGLINLEE-PC Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\CHENGL~1\AppData\Local\Temp\FaroSDK.log"
2012/11/18:20:22:16 CHENG LIN LEE CHENGLINLEE-PC Install FaroSDK Succeeded
2012/11/18:20:22:27 CHENG LIN LEE CHENGLINLEE-PC Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/18:21:52:07 CHENG LIN LEE CHENGLINLEE-PC Download Error RVT2013 <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/18:21:52:10 CHENG LIN LEE CHENGLINLEE-PC Download Aborted RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/18:21:52:10 CHENG LIN LEE CHENGLINLEE-PC Install Autodesk® Revit® 2013 Failed Download Failed, Installation aborted, Result=1603
2012/11/18:21:52:11 CHENG LIN LEE CHENGLINLEE-PC Rollback FaroSDK Failed Failure is ignored, Result=1619
2012/11/18:21:52:11 CHENG LIN LEE CHENGLINLEE-PC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/11/18:21:52:16 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2012/11/18:21:52:18 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2012/11/18:21:52:20 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2012/11/18:21:52:22 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2012/11/18:21:52:24 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2012/11/18:21:52:26 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2012/11/18:21:52:28 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2012/11/18:21:52:30 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2012/11/18:21:52:30 CHENG LIN LEE CHENGLINLEE-PC Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
Anyone can help? Thanks
