Ok I had LT 2014 on this machine two days ago. It was unisntalled. Now I am trying to install i get the "Allied Products not found" and it acts like it is contining to load. It finishes but Autocad was not loaded.
I have tried to follow all previous threads and still can't load Autocad LT. Three days now without Autocad. I have deleted all previous versions. I installed Revo Uninstaller Pro and tried to use MS FixIt but I get a fault from FixIt (see attached).
not sure what to do
Hello. Allied products usually means there is trace of another product somewhere. Uninstall through the Control Panel., use the MSfixit tool and manually delete any residual Autodesk folders:
C:\Program Files\Autodesk\
C:\ProgramData\Autodesk\
C:\Users\All Users\
C:\Users\**YOUR USERID**\AppData\Roaming\Autodesk\
C:\Users\**YOUR USERID**\AppData\Local\Autodesk\
Thank you for taking part in our community!
I have tried doing this. MSFixit can not delete the Autocad Lt 2015 application and it no longer shows up in Control Panel.
Windows 8 PC
6G RAM
Autocad LT 14 Geeting similar situatio to previous person.
ON a Mac runningOSX 10.9.5
VMWARE 6.05 (2209127)
which is running Win 7 Enterprise, 64-bit, service pack 1.
Autocad was running fine, but upgraded vmware to next update (one listed above) then could nooot open Autocad, got a message
Error: "A display driver file (.hdi) is missing or has been corrupted."
some message about not being able to load .hdi file.
Got to this link somehow tried a reinstalle of Autocad, followed the guidlines in the previous post and get a message "Allied product is not found" - see attached. If I click okay it acts like it finishes the installation but therrre is no program to pull up and run..
Any suggestions, I am totally hosed until I can get this running.
