Installation & Licensing
"adui18res.dll not found" error message.
8 REPLIES 8
Message 1 of 9
mick_mcg
33667 Views, 8 Replies
On Wednesday my Civil 3D 2010 had to be reinstalled as the full 2010 add on would no longer recognise any shortcuts like l for line or e for erase. Since the reinstall, I keep getting the error message saying "adui18res.dll not found", see screenshot attached. Having tried multiple re-installs including using revo uninstaller pro, the same error message keeps coming up when I try to run the program. Any ideas on how to fix this?
Mick
Windows 7 Enterprise
14gb Ram
NVIDIA Quadro 2000
8 REPLIES 8
Message 2 of 9
hashim.mundol
in reply to: mick_mcg
this is usually due to the failed language pack installation.
If you can post the Log file. (%temp%  folder) for the installation, it might give us some clue on why the language pack install fails.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Message 3 of 9
hi,
im having the exact same problem with autocad2011 installation.
but i cant seem to find the %temp% folder file. where can i find this?
olivia
Message 4 of 9
hashim.mundol
Start ->Run->
type %temp%
click OK
this should take you to the temp folder
Hashim Mundol
Message 5 of 9
thank you, i've successfully reached the temp folder.
which file name will tell me why this happened?
AutoCAD 2011 Setup
Olivia
Message 6 of 9
attached are my temp log files.
why has this error happened?
many thanks,
olivia
Message 7 of 9
hashim.mundol
This is a very generic error (1603) without detailed log about where it fails it is difficult to troubleshoot
You should find more log files about each of the failed component. Meanwhile please the MS KB related to this error
http://support.microsoft.com/kb/834484
Hashim Mundol
Message 8 of 9
mick_mcg
in reply to: hashim.mundol
Finally got this issue fixed...still don't know what caused it to go wrong in the first place,. fix - it was a network installation we were using pushed through by WPKG software, something must have been corrupt in there, since installed from original disc and seems to be working fine now. Thanks for your help.
14gb Ram
NVIDIA Quadro 2000
Message 9 of 9
I NEED SOLUTION TO THIS PROBLEM PLEASE SAY HOW TO RECTIFY MY PROBLEM SIR
Administrator Productivity
