Solved by ChrisVillan. Go to Solution.
I'm having the same issue with AutoCAD Architecture 2009. Could you elaborate on anything you did to get Ad32lw to work?
Thanks for the reply GL.
I tried one last thing before trying your solution.
I Installed the program on an older (soon to be decomissioned) PC (running WinXP) and was able to get it activated. From there I used the "Portable License Utility" to create a transfer file to import on the new replacement PC and it works now.
