Installation & Licensing
Questions About LMTools Autocad 2013
19 REPLIES 19
Message 1 of 20
antonio.trindade
1349 Views, 19 Replies
Hello!
I have one question abou our network configuration
we have one server that is working LMTools without problems, now we bought another server and want to configure the AutoCad 2013 License to work with that, we already had configure LMTools and the test's was that is all in UP status, as above i show
SERVER: license server UP (MASTER) v11.10
Vendor daemon status (on TSERVER):
  adskflex: UP v11.10 Feature usage info:
Allready had install on Client pc with AutoCad 2013 with the key of Autocad, with option "Network", but when we trie to open the autocad 2013, give's one message telling that "could not find any valid license" i do not know why,
I Allready tried to Stop LMTools on the other server and try the connection but same problem, the only test that we can do to is to close AutoCad 2011 clients  and stop de LMTOOLS on the old Server and Tried again with the new server!
I have no more Ideias to configure this and put this working, can anyone Help Me?
Best Regards.
19 REPLIES 19
Message 2 of 20
DarrenP
in reply to: antonio.trindade
try this: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=8385605&linkID=9240617
DarrenP
Message 3 of 20
antonio.trindade
in reply to: DarrenP
I made this configuration in Server and in the Client but with the same problem.... 😞
Message 4 of 20
DarrenP
can you post screen shots of the error message?
DarrenP
Message 5 of 20
antonio.trindade
It's in Portuguese
but her it is
Message 6 of 20
DarrenP
a -15 error is Cannot connect to license server system.
The server (lmgrd) has not been started yet, or the wrong port@host or license file is
being used, or the TCP/IP port or host name in the license file has been changed.
check your license file and see if the information in is correct especially the server name and mac address
DarrenP
Message 7 of 20
before he give's me the error of the server and after a put the name of the server but nothing.
Message 8 of 20
The -15 error is almost exclusively firewall blocking ports 2080 and 27000 and/or the client trying to connect to the server via IPv6 instead of IPv4.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Autodesk Forums:
Message 9 of 20
Can I Change the Port Name?, the other server is still working, but i want to disconnect the old server only when this is working
Message 10 of 20
It is not necessary.  Just make a firewall exception for all four .exe files and 2080 and 27000 if needed.  Make sure you can PING the server from the client and get an IPv4 address.
Autodesk Forums:
Message 11 of 20
I Do Not have that port blocked in Firewall couse the other server is runing with this port, and maybe is because of that, i think, i think because when in the other server a Stop de Server the user's are still working because they allready opened the autocad 2011 prev.
But i want to put this server working before shut down the other, that why i need o put both server working at the same time.
Both are indenpended....
Message 12 of 20
And I'm Using IPV4
Do I Need to Close all autocad 2011 Client's Before do this? can i put both server working....
only to uninstall after the 2011 version and install 2013?
Message 13 of 20
Are you trying to run two license managers on one server?  Or are these two different servers?
Autodesk Forums:
Message 14 of 20
Two Different Server
One that have Windows Server 2003 and a new one that have Windows server 2008 R2
both with different licenses
Message 15 of 20
Server 2008 R2 sometimes has issues running the NLM.  Make sure your status enquiry from LMTOOLS server status tab shows that the NLM is running and has available licenses.  Both adskflex.exe and lmgrd.exe should be listed as processes under Task Manager if it is running.
Autodesk Forums:
Message 16 of 20
-------- Status -------- Flexible License Manager status on Tue 5/29/2012 18:41
[Detecting lmgrd processes...] License server status: 27000@SERVER     License file(s) on SERVER: C:\Program Files\Autodesk\Autodesk Network License Manager\Licenses\ACD2013enlicense.lic:
Vendor daemon status (on SERVER):
Users of 64300ACD_F:  (Total of 9 licenses issued;  Total of 0 licenses in use)
Users of 85871ACD_2013_0F:  (Total of 9 licenses issued;  Total of 0 licenses in use)
Users of 85730ACD_2012_0F:  (Total of 9 licenses issued;  Total of 0 licenses in use)
Users of 85536ACD_2011_0F:  (Total of 9 licenses issued;  Total of 0 licenses in use)
Users of 71200ACD_2010_0F:  (Total of 9 licenses issued;  Total of 0 licenses in use)
I Have this in Status on LMTools, i think is everything ok...
Message 17 of 20
Open up Internet Explorer (not another 3rd party browser) on the client an type:
http://server:27000
http://server:2080
and let me know what you get.
Autodesk Forums:
Message 18 of 20
Only appears IIS page on port 80 not with 2700 and 2080,
http:\\server:80
Message 19 of 20
The above links on ports 2080 and 27000 in IE should result in a page with this:
Wê-60Wê-60Wê-60Wê-60Wê-60Wê-60
If it does not, or you get a 'page cannot be displayed' then your firewall is blocking those ports.
Autodesk Forums:
Message 20 of 20
🙂 Ok I see the firewall on server, and open those port, from some how i thought that was open, tried one more time and working like a charme
Best Regards.
And thank you for explanation
Administrator Productivity
