Installation & Licensing
Programs for Maya 2015 will not install
1 REPLY 1
269 Views, 1 Reply
Hi there
I am able to install Maya 2015 but Mental Ray Renderer and Direct Connect will not.  I saw the solution for a Temp file folder, but I already have one, and I have also installed DirectX.  I'm stumped.  Help would be appreciated since I have a project for one of my classes that I will need to begin rendering within the next couple of weeks.   I have attached error documents for both.  Overall, the error was 1603.
1 REPLY 1
TravisNave
Install	Autodesk® DirectConnect 2015	Failed	Download Failed, Installation aborted, Result=1603
 I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
