Installation & Licensing
Product Support
hashim.mundol
Message 11 of 24 (3,345 Views)
Re: Product Request Code
03-25-2011 01:06 AM in reply to: animator123
help->about->product information->activate
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
New Member
chester29
Message 12 of 24 (3,333 Views)
03-26-2011 08:24 AM in reply to: hashim.mundol
I also am having difficulty obtaining a product request code for Autodesk Inventor 2010. I have an activation code and an internet connection yet it still asks me for the request code.
Are the commands you listed in your previus post to be carried out after you open/run Autodesk Inventor 2010?
My issue is that I cannot find it on my computer to actually open/run it in the first place! I did not have this issue when activating Autodesk AutoCAD 2010.
Product Support
hashim.mundol
Message 13 of 24 (3,314 Views)
03-28-2011 04:43 AM in reply to: chester29
you can do it within the program; like i mentioned or you can do in the splash screen on initial startup.
have you installed Inventor ?
Hashim Mundol
New Member
chester29
Message 14 of 24 (3,309 Views)
03-28-2011 10:41 AM in reply to: hashim.mundol
I have dowloaded Inventor 2010 but it does not appear on my computer programs list.
It tells me on the Autodesk website that I need the request code which appears when I open Inventor, but I can not open it as I can not locate it.
I am assuming I can not install it until I have the software activated which means I need the request code.
Product Support
hashim.mundol
Message 15 of 24 (3,295 Views)
03-29-2011 04:29 AM in reply to: chester29
you only need serial number to install the product, if you don't have this yet,
please try
http://forums.autodesk.com/t5/Installation-Licensing/STUDENTS-Serial-Number-or-Product-Key-Issues/td...
Hashim Mundol
New Member
dstubbs
Message 16 of 24 (3,185 Views)
04-15-2011 03:54 AM in reply to: hashim.mundol
I am having the exact same problem.  I downloaded Autodesk Inventor, but it has not showed up anywhere on my computer, and I cannot find the program to run it.  Since I can’t run it I cannot get to the steps that it gives to find the request code.  Any suggestions?
New Member
wayneblack2002
Message 17 of 24 (3,138 Views)
04-19-2011 06:57 PM in reply to: hashim.mundol
i figured it out fellow brothers and sisters, windows/autocad problem. i kept clicking on the ativate and closing it and eventually it showed up. normally you should only have to do it once
Member
GasBus
Message 18 of 24 (3,002 Views)
05-19-2011 05:50 AM in reply to: shakmar2
ok this is getting really annoying ive downloaded 3ds Max, got my serial number and began the activasion proccess i was told from the activation guide. it aked me my serial number and i added it, then it asked the product requet code which im supposed to get when i hit the activation button once i open the software.
Now when i open the application is has 2 buttons "try" and "activate". i choose activate then i must accept the "autodesk privacy policy" and choose continue, after that the activasion screen goes blank, which is where i have to get the code i suppose...
So any help after this story ;p
Member
GasBus
Message 19 of 24 (2,996 Views)
05-19-2011 06:03 AM in reply to: GasBus
This is the proccess....
Product Support
hashim.mundol
Message 20 of 24 (2,989 Views)
05-19-2011 06:16 AM in reply to: GasBus
Please try
http://usa.autodesk.com/getdoc/id=TS1053941
If none of this work, please login as new windows user and try to activate
Hashim Mundol
