Installation & Licensing
Product Request Code
23 REPLIES 23
Message 1 of 24
maroh024
14123 Views, 23 Replies
Where can i find my product request code or can an administaotr re-run my prgram for me because evertime i try to open my program a message pops up that says i cant.
23 REPLIES 23
Message 2 of 24
in reply to: maroh024
Launch your program under a windows administrator account.
Normally AutoCAD (if this what you use) will automaticly try to activate if you have an internet connection.
If you continue to have a problem, post a screenshot of the message.
Message 3 of 24
I just downloaded autodesk inventor professional 2010 but it says i need to get a "product request code" where do i get that because i don't know how to run the pogram because I can't find it on my computer
Message 4 of 24
yea, I'm having the same exact problem. where can i get my request code for Inventor? It gave me the Product key and Serial number, but i can't find the request code. help!
Tags (3)
Message 5 of 24
I'm having the same problem. Did you ever figure it out?
Message 6 of 24
DID ANYBODY FIGURE THIS OUT?  I have been scouring the net looking for a solution to this! I am registered as a student and I CANNOT find a request code ANYWHERE!
Message 7 of 24
hashim.mundol
Activation should work automatically if you are connected to the Internet and if you have entered correct serial number,
Activation key is required only for manual methods
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=5584421&linkID=9241177
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Message 8 of 24
That's what I'm saying where do u find the request code
Message 9 of 24
hashim.mundol
You will see this when you follow the activation wizard. (help->about->product informatioj->activate if you are in demo mode)
or click on activate on the splash screen
Hashim Mundol
Message 10 of 24
how do u get to activation wizard
Message 11 of 24
hashim.mundol
help->about->product information->activate
Hashim Mundol
Message 12 of 24
in reply to: hashim.mundol
I also am having difficulty obtaining a product request code for Autodesk Inventor 2010. I have an activation code and an internet connection yet it still asks me for the request code.
Are the commands you listed in your previus post to be carried out after you open/run Autodesk Inventor 2010?
My issue is that I cannot find it on my computer to actually open/run it in the first place! I did not have this issue when activating Autodesk AutoCAD 2010.
Message 13 of 24
hashim.mundol
you can do it within the program; like i mentioned or you can do in the splash screen on initial startup.
have you installed Inventor ?
Hashim Mundol
Message 14 of 24
I have dowloaded Inventor 2010 but it does not appear on my computer programs list.
It tells me on the Autodesk website that I need the request code which appears when I open Inventor, but I can not open it as I can not locate it.
I am assuming I can not install it until I have the software activated which means I need the request code.
Message 15 of 24
hashim.mundol
you only need serial number to install the product, if you don't have this yet,
please try
http://forums.autodesk.com/t5/Installation-Licensing/STUDENTS-Serial-Number-or-Product-Key-Issues/td...
Hashim Mundol
Message 16 of 24
I am having the exact same problem.  I downloaded Autodesk Inventor, but it has not showed up anywhere on my computer, and I cannot find the program to run it.  Since I can’t run it I cannot get to the steps that it gives to find the request code.  Any suggestions?
Message 17 of 24
i figured it out fellow brothers and sisters, windows/autocad problem. i kept clicking on the ativate and closing it and eventually it showed up. normally you should only have to do it once
Message 18 of 24
ok this is getting really annoying ive downloaded 3ds Max, got my serial number and began the activasion proccess i was told from the activation guide. it aked me my serial number and i added it, then it asked the product requet code which im supposed to get when i hit the activation button once i open the software.
Now when i open the application is has 2 buttons "try" and "activate". i choose activate then i must accept the "autodesk privacy policy" and choose continue, after that the activasion screen goes blank, which is where i have to get the code i suppose...
So any help after this story 😜
Message 19 of 24
This is the proccess....
Message 20 of 24
hashim.mundol
Please try
http://usa.autodesk.com/getdoc/id=TS1053941
If none of this work, please login as new windows user and try to activate
Hashim Mundol
Administrator Productivity
