Installation & Licensing
New Member
0 Kudos
Post 1 of 24
Product Request Code
9090 Views, 23 Replies
12-08-2010 07:48 PM
Where can i find my product request code or can an administaotr re-run my prgram for me because evertime i try to open my program a message pops up that says i cant.
Please try
http://usa.autodesk.com/getdoc/id=TS1053941
If none of this work, please login as new windows user and try to activate
Valued Mentor
10 Kudos
Post 2 of 24
Re : Product Request Code
12-09-2010 02:01 AM in reply to: shakmar2
Launch your program under a windows administrator account.
Normally AutoCAD (if this what you use) will automaticly try to activate if you have an internet connection.
If you continue to have a problem, post a screenshot of the message.
Franck Hervet
S'il vous plaît Marquer cette réponse comme "Accepter comme solution" si elle répond à votre question.
New Member
2 Kudos
Post 3 of 24
01-28-2011 02:01 PM in reply to: frhervet
I just downloaded autodesk inventor professional 2010 but it says i need to get a "product request code" where do i get that because i don't know how to run the pogram because I can't find it on my computer
Member
1 Kudo
Post 4 of 24
01-28-2011 07:18 PM in reply to: nickboote1
yea, I'm having the same exact problem. where can i get my request code for Inventor? It gave me the Product key and Serial number, but i can't find the request code. help!
New Member
0 Kudos
Post 5 of 24
03-11-2011 12:39 PM in reply to: TSLDesigns
I'm having the same problem. Did you ever figure it out?
New Member
0 Kudos
Post 6 of 24
03-19-2011 06:55 PM in reply to: katbaby94
DID ANYBODY FIGURE THIS OUT?  I have been scouring the net looking for a solution to this! I am registered as a student and I CANNOT find a request code ANYWHERE!
Product Support
52 Kudos
Post 7 of 24
03-21-2011 01:10 AM in reply to: denhaus
Activation should work automatically if you are connected to the Internet and if you have entered correct serial number,
Activation key is required only for manual methods
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=5584421&linkID=9241177
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
New Member
0 Kudos
Post 8 of 24
Re: Product Request Code
03-23-2011 04:24 PM in reply to: shakmar2
That's what I'm saying where do u find the request code
Product Support
52 Kudos
Post 9 of 24
03-24-2011 02:20 AM in reply to: animator123
You will see this when you follow the activation wizard. (help->about->product informatioj->activate if you are in demo mode)
or click on activate on the splash screen
Hashim Mundol
New Member
0 Kudos
Post 10 of 24
03-24-2011 03:27 PM in reply to: shakmar2
how do u get to activation wizard
