I have AutoCAD MEP 2013 Standalone on my laptop.
I requested and recieved a link for AutoCAD MEP 2012 download.
I entered my serial # And Product Key when asked,
The product key was incorrect. How do I get the right key #
Thanks;
Mel Wright
Solved by TravisNave. Go to Solution.
Typically, the keys remain the same for the products, just the lettering increments. Since 2013 uses an E, try using the same key with a D instead for 2012. Also, the product key will be the same as the product part number, if you have that information.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=12996001&linkID=12305695
