Installation & Licensing
Product Design Suite Ultimate 2014
1 REPLY 1
zachery7
308 Views, 1 Reply
I'm running Win8 32-bit. Some products in the suite require 32, some 64, some either. Will Autodesk make all products in the suite to run on 32bit system at some stage?
Also, what if I try and install the suite on my 32bit system as is?
HELP!
1 REPLY 1
camilo.lemos
in reply to: zachery7
Hi zachery7,
At the moment we don't have any information as to when or if these products will be released for 32-bit systems as some of them - especially the media & entertainment ones - require higher performance systems to run at a good level.
If you install the the suite on a 32-bit system you may be able to run some of the products but others will simply not even install.
Best regards,
Camilo Lemos
Administrator Productivity
