Installation & Licensing
Active Member
jazapata33
Message 1 of 9 (749 Views)
Product Design Suite 2013 licensing issues
749 Views, 8 Replies
11-12-2012 06:51 AM
We just bought a new laptop for engineering and I have recently installed Autodesk product design suite 2013 on it. We have network licenses. When I connect it to the network directly through a LAN connection and try to open the software I receive an error. See attached image file.
I have taken the laptop else where and I have VPN into the server and it worked. Is there any reason this may be working with VPN but not with direct connection.
I also have checked to make sure there were enough license available for use.
Yes.  It is likely IPv6 or a combination of that and Firewall blocking ports 2080 and 27000.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982864
No problem.  It is exactly as I had predicted.  The reason you can't get licenses is because the connection trying to be made to the NLM server is IPv6.  This can be fixed by modifying the hosts file on the client machine to point to the IPv4 address (the one you PING'ed first) instead.
The entire process is in my IPv6 fix.  Instead of the 127.0.0.1 (localhost) listed in my link, use the IP address of the NLM server along with its hostname on a separate line.  That should fix you up.
Essentially your hosts file entry should look like this:
10.100.0.48     RYKO5
Then when you PING it as you did in your last screen capture, it will be correct instead of the IPv6 jargon you saw instead.
TravisNave
Message 2 of 9 (741 Views)
Re: Product Design Suite 2013 licensing issues
11-12-2012 08:55 AM in reply to: jazapata33
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Active Member
jazapata33
Message 3 of 9 (735 Views)
11-12-2012 11:13 AM in reply to: TravisNave
why would that be an issue if my workstation works fine with the same connection? Just curious.
TravisNave
Message 4 of 9 (730 Views)
11-12-2012 11:22 AM in reply to: jazapata33
Because of the IP protocol in use, would be my guess.
You might PING the server from your LAN connection with the problem and make sure that the response is a valid IPv4 address.  You can also check with Internet Explorer on the firewall ports:
http://servername:2080
http://servername:27000
Those two should give a jargon response page if open.  (replace servername with your NLM server hostname.)
Active Member
jazapata33
Message 5 of 9 (707 Views)
11-14-2012 09:16 AM in reply to: TravisNave
Alright I have the laptop connected through the LAN and have pinged the server. Here is the image of the server ping look just like my workstation ping.
TravisNave
Message 6 of 9 (704 Views)
11-14-2012 09:19 AM in reply to: jazapata33
You need to PING by hostname, not IP address.  Repost your results.
Active Member
jazapata33
Message 7 of 9 (698 Views)
11-14-2012 10:33 AM in reply to: TravisNave
alright Here is what it looks like after I ping to by the server name. Also I am fairly new to all of this installation information so bare with me please.
TravisNave
Message 8 of 9 (692 Views)
11-14-2012 10:42 AM in reply to: jazapata33
10.100.0.48     RYKO5
Active Member
jazapata33
Message 9 of 9 (687 Views)
11-14-2012 10:58 AM in reply to: TravisNave
Thanks for all your help. your solutions has fixed the issue.
