I downloaded the 2012 Product Design Suite from the Subscription Center and I'm presently trying to build the deployment package. We run a network license/single license server setup. In the past, I don't believe I entered a serial number and product key because the license was obtained over the network. In any case, I can't move past this point in the deployment because the "Next' button is grayed out making me believe it wants me to enter the Serial number and product key. The problem is that I can't find this information because I downloaded the software from the Subscription Center. Where can I find this info? Is there some text file embedded in the deployment?
Thanks!
Solved by dagumad. Go to Solution.
Hello mrm01,
Only the contract manager and software coordinator has
access to the Serial Number and Product Key within the subscription center. Please contact your CM/SC for this information. If you the CM/SC, please follow the instructions
below to locate your SN and Product Key:
1. Click
"Contract Administration" link on the left side of Home Page
2. Select "Coverage Reports” link.
3. Click on the Contract number and the Serial numbers and product
details will display
4. In "Release" column look for the year for the serial number
(click on the serial number to reveal the previous year)
5. The Product Key will be in the column adjacent to the serial number
