I've been trying to install AutoCad 2015 student version without success. No matter what download method I use, I still get the error that the "procedure entry point could not be located in the DLL." I did try Workaround #1 suggested here, but no success. (#2 didn't apply to me, I am doing this on my home laptop.) I'm using Windows 8, and have recently updated all my drivers. Any suggestions you have would be appreciated.
Go ahead and try workaround 2 from that page I have seen it workaround that error alot. Specificly this
This will make the setup ignore errors related to that dll file and hopefully allow the install to proceed. Can you confirm that LiteHtml.dll is the dll file mentioned in the error? If it's a different dll you may have a different issue.
