Installation & Licensing
Problems with Win7 & ACAD2000, Please help!!
4 REPLIES 4
mytoyagain
296 Views, 4 Replies
Hi, guys, i need help.
Bought a new Win7 Pro (32bit), installed ACAD2000 smoothly into both Win7 & windows XP mode with hardware lock dongle attached,
but i can't run this software, cos it show me an error message:
would anyone please advice.   Thanks!!
4 REPLIES 4
TravisNave
in reply to: mytoyagain
Really?  Autodesk products circa release 2010 and newer are supported on Windows 7.
Your product is not supported natively on Windows 7 nor in compatibility mode. Your best bet would be to install the Windows XP Mode virtual machine from Microsoft and install it there.  It is a free download for Windows 7 users.
http://www.microsoft.com/windows/virtual-pc/download.aspx
Chances are though it still won't be able to find your dongle.  Good Luck!
Autodesk Forums:
mytoyagain
in reply to: TravisNave
Yes, my new PC with XP mode installed, and acad2000 installed as well,
its doesn't work.   I found that quite numbers of forum members saying that,
ACAD2000 run smoothly on XP mode environment.
i dont think that is an error with the Parallel port.
TravisNave
Yeah but the parallel port is emulated and not the physical port. It's unlikely to work. You'll probably need a native XP host machine.
Autodesk Forums:
mytoyagain
By the way,
i wonder your 2000 come with the hardware lock dongle as well??
Well, may be u are right,
the only way i can do right now is exchance a XP host machine from my colleague,
back to the old age.........   ;(
otherwise have to spend some money to do the CAD upgrading to 2012.
Administrator Productivity
