After the installation product,later I introduce my serial number and my product key (student) , when i try to begin the program he fail with this dialog:
Cannot initialize lincense manager: ADLM: startup failed
Suggest Solutions:
1:Verify the lincese manager is running, and ensure connectivity.
2. Verify that the lincese has not expired.
3. Verify that the lincese is for the current version of Autodesk Simulation CFD "
I have read some things about the network lincense but somebody can explain me why I have to have a master in informatic for install this program?
HI eduardo.mas,
This is a know issue with one potential solution linked here. Please give it a go and let us know if you're able to get through the install.
Hi asvind,
I understand you ran the batch file. To re-confirm, please do a manual check on the following Registry key: \HKLM\software\Autodesk Simulation CFD\13.0\Locale and see if the value is en-US. If it is not, please change it to en-US. See attached.
Thank you.
Hi asvind,
Thank you.
Hi asvind,
Please Telnet to the license server port 2080 to determine client -to-server connectivity is good.
- Go to command prompt (eg. C:\)
- Type “telnet servername 2080” (without quotes and servername is the License Server name)
- Hit <Enter>
- If you get a blank screen, it means the connection to License Server is good
- But if you encounter error messages, it means the connection to License Server Port 2080 is blocked, probably by Firewall. Please contact IT officers to open and allow connection to Port 2080.
Thank you.
