Installation & Licensing
Problems with licence transfer utility for 2010 3d map
2 REPLIES 2
222 Views, 2 Replies
Hey im swapping out computers and trying to transfer the licesence from the old computer to the new but when i go to click on licsence transfer utility it will not even open nothing comes onto the screen and when i look under the processes tab on the task manager the image name will show up then crash. ive transfered the other licsences on other machine for autocad and havnt had a problem im not sure if theres another way to go about transfering of the licsence or how to even just get licence transfer unility to open
2 REPLIES 2
antoniovinci
Well, this is a technical forum: your question is formal, so you'll get the right answer only from your Authorized Dealer, sir.
TravisNave
The license transfer utility works slightly less than never.  You should be able to just reactivate your product.  If you are out of activations, call Autodesk Activations and they will give you a new activation code.
Please call Autodesk Product Registration and Authorization:
http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
1-800-551-1490 > Option 1 (English) > Option 1 > Stand-alone
You will need your serial number and request code.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
