I have tried downloading Autodesk Inventor Pro multiple times, all different ways. When I do an install now, I get all of the way to the end of the install and it tells me that it couldn't download the software. Then when I do a Browser Download it will not finish the download. When I do a Download Now, I am able to hit run and then it gives me nothing else. I really need some help. I have Windows 8 64-bit, so maybe I am having problems with the computer, but I really need some help.
Hi Preston,
Welcome to the Community. Could you try using the links below instead to download the Autodesk Inventor Professional 2014 installer?
Autodesk Inventor Professional 2014 for Windows 32-bit
Autodesk Inventor Professional 2014 for Windows 64-bit Part 1
Autodesk Inventor Professional 2014 for Windows 64-bit Part 2
Kindly note that for the 64-bit installer, you'll need to save both files into the same folder first before running the part 1 .EXE file to initiate file extraction and installation. Let us know if you are still not able to download/install the program.
