Installation & Licensing
Problems reinstall AutoCAD Civil 3D 2013
1 REPLY 1
273 Views, 1 Reply
After unistalling AutoCAD Civil 3D 2013, I can't install it again. I remove all autodesk folders and removed autodesk folders in registry. But after launching setup exe of AutoCAD Civil 3D 2013 and 2012 every time only Object enabler can be installed. The setup doesn't run properly. What can this be? Thanks anke
1 REPLY 1
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Good Luck!
Autodesk Forums:
Administrator Productivity
