If your error message is "AutoCAD component has encountered a problem and needs to close".This message indicates a problem with one of the Microsoft components that are required for AutoCAD to run successfully.
To resolve the problem, please do the following:
Boot the machine into diagnostic mode as follows:
- Click Start > Run > type msconfig and press ENTER
- On the General tab, select "Diagnostic Startup"
- Switch to the "Services" tab
- Put a checkmark in the box next to "Windows Installer" Service
- Click OK to reboot with the changed configuration
After the machine has rebooted, log on as Administrator and do the following:
- Via the control panel, uninstall all installed versions of Microsoft .NET Framework
- Likewise uninstall all installed versions of Microsoft Visual C++ Redistributable
- Reboot again into diagnostic mode as descibed above
- Insert the AutoCAD 2010 DVD
- In Windows Explorer, navigate to the DVD and open the folder ..\x86\ if running a 32-bit operating system, or \x64 if running a 64-bit operating system.
- Open the folder \support\dotnetfx\wcu\dotNetFramework and execute the file dotNetFx35setup.exe to reinstall Microsoft .NET 3.5
- Navigate to the folder ..\support\VCRedist\2008\x86 and execute the file install.exe to install Microsoft Visual C++ 2008 Redistributable
Next, boot the machine into normal Windows mode:
- On the General tab, select "Normal Startup"
After the machine has rebooted, start AutoCAD and attempt to reproduce the problem
Emily Xu, Autodesk Product Support
We appreciate your quick feedback on this forum
Emily Xu
Product Support
