Installation & Licensing
Problems installing Revit Architecture 2012 30 day trial
3 REPLIES 3
jsmith
875 Views, 3 Replies
After downloading trial version, and proceeding with install, on the "installation progress" page, it keeps freezing on step 4 of 7 remaining. The "installing" bar at the top is about 90% finished, then stops moving completely. Gave it plenty of time and 3 attempts.. not sure what to do. Using a dell T3500 with windows 7.
3 REPLIES 3
david.lau
in reply to: jsmith
Can you turn off UAC before installing it?
http://upandready.typepad.com/up_and_ready/2011/05/windows-user-access-control.html
David Lau
jsmith
in reply to: david.lau
Thanks for the reply. It seems like I don't have an "on/off" switch for UAC. I did find 4 options referring to when I would like to be notified about changes to the cpu.. and it was already on the lowest setting.  (see attached)
benjamin_kapfinger
in reply to: jsmith
hello,
i have exactly the same issue did you solved the problem?
bk
Administrator Productivity
