Installation & Licensing
New Member
jsmith
Message 1 of 4 (750 Views)
Problems installing Revit Architecture 2012 30 day trial
750 Views, 3 Replies
09-14-2011 05:23 AM
After downloading trial version, and proceeding with install, on the "installation progress" page, it keeps freezing on step 4 of 7 remaining. The "installing" bar at the top is about 90% finished, then stops moving completely. Gave it plenty of time and 3 attempts.. not sure what to do. Using a dell T3500 with windows 7.
Product Support
david.lau
Message 2 of 4 (738 Views)
Re: Problems installing Revit Architecture 2012 30 day trial
09-14-2011 10:07 AM in reply to: jsmith
Can you turn off UAC before installing it?
http://upandready.typepad.com/up_and_ready/2011/05/windows-user-access-control.html
David Lau
New Member
jsmith
Message 3 of 4 (733 Views)
09-14-2011 10:37 AM in reply to: david.lau
Thanks for the reply. It seems like I don't have an "on/off" switch for UAC. I did find 4 options referring to when I would like to be notified about changes to the cpu.. and it was already on the lowest setting.  (see attached)
Member
benjamin.kapfinger
Message 4 of 4 (512 Views)
01-24-2012 07:21 AM in reply to: jsmith
hello,
i have exactly the same issue did you solved the problem?
bk
