I've downloaded the program repeatedly and get the same error everytime.
Entry Point Not Found
The procedure entry point
?Getcat@?$codecvt@DDH@std@@SAIPAPBVfacet@locate@2@PB42@@Z could not be located in the dynamic link
library
C:\Autodesk\Flow_Design_2014_English_WIN_64bit_dlm\Sepup\LiteHtml.dll
thanks for replying
I tried :
install now, download now and browser download
no option worked
I download the file Flow_Design_2014_English_WIN_64bit_R1_dlm.sfx
after installation, when trying to run the program this message appears
The program can´t start because mfc110u.dll is missing from your computer. Try reinstalling the program to fix this problem
Mine is located here:
C:\Windows\System32
Details are attached. I think you will need to use Procmon to find out if you have a 3rd party program that make be located in a different 'path'. It is similar to the workflow noted here:
http://upandready.typepad.com/up_and_ready/2013/09/revit-crash-at-startup.html
Do you have another computer to install it on? That maybe an easier test.
Yes. I installed the program on my wife's pc, and it worked without any problems, although the computer does not have the recommended hardware requirements.
