I've installed almost all products of the Building Design Suite Ultimate 2013 and all programs starts up without any problem, except AutoCAD Structural Detailing.
It seems that it opens an AutoCAD instead of ASD. When checking the loaded profile it's AutoCAD.
When changing the active profile to AutoCAD Structural Detailing I'll get all of the workspaces. But when using a button of ASD I'll get following message: rbcr_def_bar_bv Unknown command "RBCR_DEF_BAR_BV"
When I'll check the support file paths, it's seems that not the correct paths are loaded.
It's also has infected ASD2012. Suddenly ASD2012 doesn't longer find his database.
My collegue has the same problem! So I think I can conclude it's a software problem?!!
Printscreen of the path that suddenly is used in ASD2012 to find his databases:
In the past the path was: C:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Reinf
This is problem with the shortcute created with BDSU 2013. Easy fix is to change the shorcut > Target as
"C:\Program Files\Autodesk\AutoCAD 2013\acad.exe" /ld "C:\Program Files\Autodesk\AutoCAD 2013\ASD\ASD.arx" /p "AutoCAD Structural Detailing" /product ASD /language "en-US".
Hope this help.
Best regards,
Dhanjeet Sah
