Installation & Licensing
Problems during Installation progress
2 REPLIES 2
gonmaal
292 Views, 2 Replies
My name is Gonzalo and I have a new computer with Windows 8.1.
I´ve been trying to install products like Autodesk Showcase 2015, Autodesk 3ds Max Dessign 2015 and Autodesk 3ds Max Dessign 2014, all of them for 64bit processor and with 3-year free student license.
In all the cases I had the same problem: I run the installation and in the beggining of the progress, when 560Mb aprox. were already downloaded, the download speed began to descend from 2Mb/s till 1b/s. The remaining time was like 1212 years and obviously I had to stop the download. First I thought It was a problem with my connection, but I tried to download it at the University and I had the same problem.
If you have any solution to my problem please reply me.
Thanks.
2 REPLIES 2
TravisNave
in reply to: gonmaal
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
gonmaal
in reply to: TravisNave
Thank you Travis, I will try this procedure.
Administrator Productivity
