We're four months into this issue with no resolution in sight. Any and all help appreciated.
Background: Server Alpha has 9 AutoCad 2010 license and LMT running. User in two offices (local and a branch) log on fine. Ports are open and no firewall is in place.
Late last year a "bundled" package was purchased. This included REVIT 2012 and additional network and subscription licenses for AutoCad 2010. Vendor said we could put this all in one license file on Server Alpha and we'd now enjoy 13 AutoCad 2010 users, plus the additional products we purchased.
Well, that didn't work.
So, per their recommendations, we put a license file on Server Beta. This one holds REVIT, plus the additional 4 Arch2010. We made changes to each user's environmental variables so Server Alpha was selected first and if no license was available for Arch2010, then a license would be pulled from Server Beta.
Well, that didn't work also.
Round two. Extend the timeout to 100000. Modify Licpath.lic so the users point to one server or the other as their default. Well, no luck either.
Again, any and all suggestion welcome as this has been a huge production disruption.
When we used a combined license for all AutoCad products, we ended up exactly where we are now. Once we had 9 logins, we could not get the additional 4 issues. Had to jump through the same hoops of having staff log out.
thanks for asking.
Did you get the licenses files generated on the same day so that they cascade into one another?
Also I was advised to place the suite license after the main AutoCAD license in the license file on the server.
Finally what sort on numbers did the Perform Status Enquiry give on the AutoCAD 2010 feature Users of 71200ACD_2010_0F:?
It appears the license file was generated same day. See below. Regarding the status inquiry, we would receive a "8 of 9 " issued as one user had borrowed a license. I inserted X and Y for server, serial number and mac address info, fyi.
SERVER XXXXXXXXXXXX YYYYYYYYYYYY4
USE_SERVER
VENDOR adskflex port=2080
PACKAGE 85787BDSPRM_F adskflex 1.000 COMPONENTS="85787BDSPRM_2012_0F \
85536ACD_2011_0F 85652BDSPRM_2011_0F 85503MAXDES_2011_0F \
85561ARCHDESK_2011_0F 85595STRDET_2011_0F 85562BLDSYS_2011_0F \
85607SHOWCASE_2011_0F 85615ALSK_2011_0F 85587REVIT_2011_0F \
85543REVITST_2011_0F 85541RVTMPB_2011_0F 71200ACD_2010_0F \
83900MBXPRO_2010_0F 82200STRDET_2010_0F 72200ARCHDESK_2010_0F \
70000MAXDES_2010_0F 74100REVIT_2010_0F 73900REVITST_2010_0F \
73800RVTMPJ_2010_0F 73000BLDSYS_2010_0F 82400RVTMPB_2010_0F \
57600ACD_2009_0F 59900BLDSYS_2009_0F 60100ARCHDESK_2009_0F \
612003DSMAX_2009_0F 62100REVIT_2009_0F 62200REVITST_2009_0F \
67800RVTMPJ_2009_0F 85614RVTMPJ_2011_0F" OPTIONS=SUITE \
SUPERSEDE ISSUED=13-Jan-2012 SIGN="1C7D C127 BF0D 446E 8C3E \
D239 9033 C298 C0D8 E00E AD81 C9FF D0FD 85BF 780E 0E55 2862 \
AD8B 1123 0428 B5E8 4175 31AB BF15 E279 6F9D 46E7 C06B 807B \
7B04" SIGN2="10F9 6232 CB2B F2FC 6F68 84D9 A421 DE3D E88E E9EB \
D1BF FC7F 82B7 109E 1E96 1144 E5DF A9F3 AEDE C474 D3DB 36BC \
67AF 0435 6D61 BC58 5EDA 4574 134D E9F9"
INCREMENT 85787BDSPRM_F adskflex 1.000 permanent 1 \
VENDOR_STRING=commercial:permanent SUPERSEDE DUP_GROUP=UH \
SUITE_DUP_GROUP=UHV ISSUED=13-Jan-2012 BORROW=4320 \
SN=XXXXXXXXXXXX SIGN="0DC2 48D2 79E1 CBEE 0AFD BE46 DC94 75F5 \
F13E F3F2 DD29 A04A F987 CD5C ACE3 0789 4B89 DB73 9A31 436D \
F43A 1241 4A73 B7BB 33C9 4560 356C 4487 D975 382F" SIGN2="05D1 \
61D6 DBE3 CBC6 66DC F012 A07E 80E0 0B51 5858 2479 A29F 85DE \
5B7E FA80 188C 6795 B12F 2491 EB37 FFD5 F739 24E1 7045 BDF0 \
39AF 6498 9302 D4C8 4303"
INCREMENT PLIST adskflex 1.000 permanent 1 \
VENDOR_STRING=A07:51600ACDLAND_2007_0F:52200CIV3D_2007_0F;B07:51900AMECH_PP_2007_0F:51300INVBUN_11_0F:52900INVPRORS_11_0F:53000INVPROSIM_11_0F:51400INVPRO_11_0F;C07:51200ACD_2007_0F:52500REVITS_9_0F:54100REVITS_9_1F:53700REVSU_3_0F:54200REVSU_4_0F;D07:52600REVIT_9_0F:52500REVITS_9_0F;E07:57600ACD_2009_0P:59300INVBUN_2009_0P;F07:51800BLDSYS_2007_0F:53100REVSYP_1_0F:54500REVSYP_2_0F;G07:53400REVITST_3_0F:53700REVSU_3_0F;H07:54300REVIT_9_1F:54100REVITS_9_1F;I07:54400REVITST_4_0F:54200REVSU_4_0F;A08:55500ACDLAND_2008_0F:55400CIV3D_2008_0F;B08:54900AMECH_PP_2008_0F:55000INVBUN_2008_0F:55100INVPRORS_2008_0F:55200INVPROSIM_2008_0F:55300INVPRO_2008_0F;C08:54600ACD_2008_0F:54700REVITS_2008_0F:54800REVSU_2008_0F;D08:57100REVIT_2008_0F:54700REVITS_2008_0F;F08:55600BLDSYS_2008_0F:55700REVSYP_2008_0F;G08:57200REVITST_2008_0F:54800REVSU_2008_0F;A09:59800ACDLAND_2009_0F:59700CIV3D_2009_0F;B09:59200AMECH_PP_2009_0F:59300INVBUN_2009_0F:59400INVPRORS_2009_0F:61700INVMFG_2009_0F:59500INVPROSIM_2009_0F:59600INVPRO_2009_0F;C09:57600ACD_2009_0F:59200AMECH_PP_2009_0F:78400ACDDS_2009_0F:60900REVITS_2009_0F:61000REVSU_2009_0F;D09:62100REVIT_2009_0F:60900REVITS_2009_0F:78200RAV-S_2009_0F;F09:59900BLDSYS_2009_0F:60000REVSYP_2009_0F;G09:62200REVITST_2009_0F:61000REVSU_2009_0F;J09:67800RVTMPJ_2009_0F:60000REVSYP_2009_0F;K09:68800CIVIL_2009_0F:59700CIV3D_2009_0F;L09:60100ARCHDESK_2009_0F:60900REVITS_2009_0F:78200RAV-S_2009_0F;M09:68900NAVREV_2009_1F:78200RAV-S_2009_0F \
SUPERSEDE ISSUED=13-Jan-2012 SIGN="04F9 A9E5 7309 5B95 43BD \
8B50 D649 EF30 35E5 90AC 611E F33E 343D D784 DB3D 0554 7711 \
AB43 46DE 14DF 605B 3609 983C BDB5 CAB0 44A2 A7C2 AC00 183E \
E021" SIGN2="0832 AFD1 3FBD 4791 0DB5 B703 C34F 3EFB 7859 3E24 \
26E9 4341 96C1 55C7 7411 11AF 2CFF 57A8 C804 D092 DFBD 6A4E \
45B1 50F8 43C8 426F 2755 6284 F2A9 61D7"
SERVER XXXXXXXXXX YYYYYYYYYYYY4
USE_SERVER
SN=XXXXXXXXXX SIGN="07C2 00DC 3BFE 338E 67DE B557 0697 E378 \
424C 8061 FCDE E9F1 D618 EAB8 2AB5 1AEF 5F39 B6E5 5EE2 3729 \
A19A 4D76 8809 9FF5 5C46 5EC1 C070 1A9D DA84 09DE" SIGN2="1876 \
8CDE 29EF FD7E DFAB CDD3 5F89 BF25 CA27 6F75 BE80 D0CA 5C27 \
9D5F DAC2 149C 8457 817A D505 D97B FE5E D476 4736 63B9 3245 \
AB43 B6A4 9706 8829 958A"
SERVER XXXXXXXXX YYYYYYYYYYY44
USE_SERVER
PACKAGE 65300ARCHDESK_F adskflex 1.000 \
COMPONENTS="85731ARCHDESK_2012_0F 85561ARCHDESK_2011_0F \
72200ARCHDESK_2010_0F 60100ARCHDESK_2009_0F" OPTIONS=SUITE \
SUPERSEDE ISSUED=13-Jan-2012 SIGN="0F8B E825 7785 A180 B1DB \
47C8 8503 8A1D 94B9 EB2C C070 9202 BE33 D334 14A9 1171 8D56 \
AB0B AB21 955A D565 84C2 A959 4AAD F154 ABD4 0BF9 9A23 7DDC \
51F7" SIGN2="16B4 A312 EE74 CB91 DC62 974B 5B51 EF31 9A8F 9035 \
8DD0 51CC 74DE 10CD E6E3 1A50 9D85 E21F 3830 1D35 693E FEAF \
43F1 C097 595D 375D 8277 AEA1 DBB4 2256"
INCREMENT 65300ARCHDESK_F adskflex 1.000 permanent 1 \
SN=XXXXXXXXXXX SIGN="1581 A8CB B78D 094A F252 8056 5453 6D53 \
C243 F7B1 CF56 92DF 8EBA 4E16 FFDD 1930 33BD 1883 7B25 02AD \
C8BF 4D85 A929 FECF 3FBC AAF0 B241 6B4C 3D9E DFCB" SIGN2="0284 \
6285 5D18 034F 35B0 2F3F E82E FCA5 F12A 164B 72F4 B7B7 F662 \
EAC3 F027 1E83 5CF5 62D7 07FD 1432 70AE 06C6 095B D5F8 7595 \
4E2D 679A 981C F8F1 376B"
SERVER XXXXXXXXX YYYYYYYYYYYYYY4
USE_SERVER
SN XXXXXXXX SIGN="0132 8D38 43D0 9913 E606 A2C5 24C9 AB7F \
E1AC 1113 4C56 48EA 3FBE 99A5 8A22 17EB 68D8 8E4D EFBD 0AFC \
0D96 C4D5 95F9 722E C687 F0D6 A210 46B4 1303 D34F" SIGN2="0D1A \
57DB 0CC8 765B B0D1 14F0 3A82 A328 DA43 F30B 7177 2442 2CBF \
D9A9 ADB2 1B4E A675 29E9 D0ED F4AD 2F1A 4D1B 1C56 EECE A157 \
6A39 0B1A 41F1 8383 36BB"
Did you run the Perform Status Enquiry with just the suite license on the server to see that it was reporting correctly?
Also the initial inquiry seems to be off when you run it as it only reports AutoCAD 2012 license numbers you have to
scroll down to get the correct count for 2011, 2010 and 2009 ours reports 40 2012 licenses but as we scroll down it then hits 46 when it then decides to add in the 6 suite licenses for the other versions.
Also we help we discovered that AutoCAD 2012 won’t pull a license from the server if it hasn’t been installed from the suite using its serial number.
We have two Suite users. In the middle of this trouble, I was able to determine via the status inquiry that there were 2 available, 2 issued. But, the license file was in the combined file, not just the only thing on the server.
I believe I understand your point about the count. I'll check this out with our AutoCad reseller support techs who have been working on this for us. I have a meeting tomorrow and I'll see what they say.
One other thing did the license tools on the server get upgraded to the latest version?
Also have you tried stacking the licence file with the AutoCAD at the top and the suites at the bottom?
