I had some problems with the AutoCad 2017 installation on my pc. Here photos of the error:
Can you help me?
Solved by Mark.Lancaster. Go to Solution.
I would recommend that you try downloading your product using the Virtual Agent by following the directions here:
https://knowledge.autodesk.com/customer-service/download-install/download/download-previous-versions...
I tried to do what you had said me, but an error about the language pack apeard in the installation of the firs part and the second part...
At this point you have a messed up system..
Follow the steps in the article to fix your issue.
Mark Lancaster
& Autodesk Services MarketPlace Provider
But now, I had another problem...
So, for the first problem I had reinstalled and reinstalled the software, so I want to know if is possible to correct this error without uninstalling and reinstalling the software... can you help me?
You know you can help yourself... Doing a search in Google would've pointed you to this article.
Mark Lancaster
Yes, I'd already read this article, but I want know if I can fix the problem without uninstalling everything...
Can it be done? Maybe.. But mostly likely not. Just do it and get it done..
Mark Lancaster
