Installation & Licensing
Problem with Plant 3D trial Install
3 REPLIES 3
samsonthomas7606
484 Views, 3 Replies
Our network administrator installed the Plant 3D 30-day trial on my computer( win XP SP3). When I try to run, it gives me the "AutoCAD Error Aborting". Please see attached jpeg. When administrator log on to my computer software loads fine. Any suggestion is greatly appreciated.
Samson Thomas
3 REPLIES 3
Do you have local Administrator rights on your computer?
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thanks for reply.  Yes, I do have the administrator rights.
Then it could be a problem with your Windows profile.  You could have another user with local admin rights login and see if the program works.  That should narrow it down to the profile or not.
Autodesk Forums:
Administrator Productivity
