Installation & Licensing
Problem with Material Editor in 3ds Max
1 REPLY 1
823 Views, 1 Reply
Hi!, I just installed 3d Max and I have encountered a problem in the material editor, since in the Material / Map Browser appears not map any bitmap and style. No may be happening.
This is the view that the program gives me when I try to add a map:
If someone could help with this issue would be very grateful, do not understand why this happens.
Thanks!
1 REPLY 1
TravisNave
You should probably post this in the 3DS Max forum.
http://forums.autodesk.com/t5/3ds-Max/ct-p/area-c1
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
