hi. i am using windows 7 ultimate 64bit. i am trying to install autodesk 2014 and i am getting an error which has no log report. but while i was observing the installation, i found out where it is giving the error. it is in the begining between installing DirectX runtime and misrosoft visual c++ redistributable packace. i tried to uninstall c++ and install autodesk and i didnt work. and then i install c++ again and tried to install autodesk but having the same issue again. i added the screenshot . i hope i can get an answer as quick as possible because i cant do my job because of this problem... thanks for now
okay travis but yesterday after all attempts, i downloaded the programs one by one. i needed inventor and autocad mechanical. so product design suite packace didnt wotk. but i downloaded them and installed seperately. had no problem. but i added here the log file list because there are too many. i tried to install so many times so let me know which file i should look at...
The Autodesk Product Design Suite 2014 one. That was the one associated with the image in your OP.
Thanks.
