Installation & Licensing
Member
0 Kudos
Post 1 of 4
Problem with installing Revit Structure 2013
449 Views, 3 Replies
12-29-2012 09:14 AM
I have a problem while installing Revit Structure 2013. I am using the install from harddrive and my computer runs windows 8.
When the install says 6/9 remaining, a pop-up shows with the text: "Preparing Revit Content" Screenshot 1
It keeps loading for a while, but then the install-program tells me that the installation has failed Screenshot 2.
I have googled it offcourse, but the guide I found did not work (this one). The screenshots are in dutch, but I think you'll understand them. Firs of all I set the bar on low Screenshot 3 to make sure, and I've added *.Autodesk.com Screenshot 4 on the pop-up when I click on website. Jjust *Autodesk.com (without the dot)did not work. I also changed from Firefox to Internet Explorer to be my main-browser to make sure these settings work.
Hope someone can help me,
Jeroen
9 Kudos
Post 2 of 4
Re: Problem with installing Revit Structure 2013
12-29-2012 11:48 AM in reply to: jeroendewind
As far as I am aware Revit Structure 2013 is not supported with Windows 8.
Do a Google search for Autodesk products and Windows 8.
Trust this helps.
Member
0 Kudos
Post 3 of 4
12-29-2012 01:00 PM in reply to: jeroendewind
Thanks, assumed it would be allright but apparently it's not.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
Member
0 Kudos
Post 4 of 4
01-04-2013 07:03 AM in reply to: jeroendewind
I've searched some on internet and also asked around. Apperently its officially not supported, but like most other programs, it should work on W8. Anyone here who knows what to do? I think now that the problem is more the 'Preparing Revit Content' pop-up instead of my W8.
Post to the Community
New Post
