I'm working in a small architecture company, recently we are trying to upgrade most of our CAD's to 2012 version.
What we're trying to do is install from a network deployment, but we're getting an error which states that the 'temp' directory is not empty or disk is full and setupres.dll can not be found [error code 126] and the installer closes. Cleaning or changing the 'temp' directory doesn't change anything. Strangely it only happens with 32bit version of the software, 64bit is working as intended.
Microsoft's .NET 4.0 and latest directx was installed prior to installation.
Is there something more that I can try to make it work? 🙂
Best Regards
/Christopher
You may not have write permissions to some of the directories on the network that the installer is attempting to access.
