Installation & Licensing
Problem with activation (error activation) error (400)
260 REPLIES 260
Message 1 of 261
60727 Views, 260 Replies
Hello
I have a problem with activation autodesk Autodesk 3ds Max 2012 64-bit
the problem is that:
 When I clicked on "Activate" and next "Continue" the next screen was "Processing Error"
Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems.
 Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days.
I have a student license
260 REPLIES 260
Message 101 of 261
in reply to: joane.bonghanoy
I got error 400 and can't use my Autocad 2014 64-bits. Can you help me?
Message 102 of 261
Still w8ing...
Message 103 of 261
camilo.lemos
Hi gkki,
I've just replied to your private message.
Best regards,
Camilo Lemos
Message 104 of 261
Hi
I have the same problem with activation the Autodesk 3Ds MAX 2014  64-bit. (error 400) I have a student license. Can you help me with activation? Thank you in advance.
Message 105 of 261
joane.bonghanoy
Hi dahunpao,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Request Code so I can manually generate the Activation Code.
Joane Bonghanoy
Message 106 of 261
I sent a request code 3 days ago, still waiting for help.Man Sad
Message 107 of 261
camilo.lemos
Hi dahunpao,
Could you send me the serial number and request code via Private Message and I'll get this sorted for you right away?
Thank you and apologies for the delay.
Camilo Lemos
Message 108 of 261
in reply to: camilo.lemos
Big thanks for help, great job.
Message 109 of 261
I also got a problem with the activation of 3ds Max 2014. Can someone help me?
Thank you.
Message 110 of 261
philip.s
Hello Ãliott!
As this will require an activation code be generated on our end, can you please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number and request code, or contact our License Assistance Team for direct support.
Message 111 of 261
I got a problem with the activation of 3ds Max 2014. Can someone help me?
Thank you.
Message 112 of 261
joane.bonghanoy
Hi Ãliott,
Please send me a Private Message (click on my joane.bonghanoy profile name and then “Send this user a private message”) with your Serial Number and Request Code.
For future reference, you can also contact our Registration and ActivationRegistration and Activation team directly for any activation issues.
Joane Bonghanoy
Message 113 of 261
Hi! I'm having the same problem when I try to activate 3DMax 2013. I had the same problem a few months ago when I tried to activate other autodesk programs. Could you help me?
Thank you.
Message 114 of 261
camilo.lemos
Hi alolpe,
Can you please send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)?
Thank you,
Camilo Lemos
Message 115 of 261
Hello, mi name is Cesar and  i have the same problem with mi activation code. I click on activate , and the program show me this :
Please help me!!!
Message 116 of 261
joane.bonghanoy
Hi Cesar,
Joane Bonghanoy
Message 117 of 261
I sent my serial number and request code four days ago, I'm still waiting.
Thank you.
Message 118 of 261
I´m having the same problem but with the AutoCAD Electrical 2013 64-Bit
can some one please help me
Message 119 of 261
camilo.lemos
Hi attto85 and welcome to the forums!
Please send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)
Thank you,
Camilo Lemos
Message 120 of 261
fredrik.karl.bengtsson
Hello
When I try to activate 3DS MAX 2013 64-bit (student version) I get error (400) message. Please help.
Administrator Productivity
