Hello
I have a problem with activation autodesk Autodesk 3ds Max 2012 64-bit
the problem is that:
When I clicked on "Activate" and next "Continue" the next screen was "Processing Error"
Your online activation request has returned an error (400) which is not allowing your request to be processed using our automated systems. |
Click the "Use another method" link below to complete the necessary forms and submit your request to the local Autodesk Business Center for your area. A Customer Service Representative will respond within the next 2 business days.
I have a student license
Solved by jessica.t. Go to Solution.
I have the same problem with activation the AutoCAD 2012 64-bit. I have a student license. Can you help me with activation? Thank you in advance.
Hello Dmitry,
Can you please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request code, or contact our License Assistance Team for direct support.
My sincere apologies for the delayed response / I must have missed that earlier. I just responded to your PM with an activation code, and please let me know if I can be of additional assistance.
Hi joostbos and welcome to the community!
Are you getting any error messages when you try to activate? Can you please send me your serial number via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)?
Thank you,
i have the same problem but with revit architecture can somebody help me?
Hi Veronica2812,
Can you please send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message).
Thank you!
Hello support,
I have the same problem activating Maya 2014 64-bit. I have a student license. Could you help me with manual activation, too? Would be great and thank you in advance.
Sure thing Alexander!
Can you please either send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number and request code, or contact our License Assistance Team directly.
Hello Theo!
I've just processed your activation code request which you should have received via email. Please let me know if that's not the case and I'll gladly pass it on in Private Message.
Anyone else that finds themselves in a similar situation can also contact our License Assistance Team for direct support.
Sure thing Shannon!
Are you able to send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request code?
Sure thing!
Can you also send me a Private Message (click on my philip.s profile name and then "Send this user a private message") with your serial number + request code or contact our License Assistance Team for direct support?
Hi Andrea!
I just stumbled upon your Private Message and while it looks like you received your activation codes already, I wanted to double check to make sure.
For future reference and in order to guarantee a timely response, please ensure that you have already posted in the forums and received an invitation prior to jumping into a Private Message convo 🙂
If you need immediate activation assistance, the best bet is to simply contact our License Assistance Team.
i have a error (activation) error 400 with autodesk autocad 2014 ... i have a sutudent license ... please help me ..
Hi Andres,
I'm seeing here that your Serial Number for Autodesk AutoCAD 2014 has been successfully activated 8/15/2013. It should be good to go and you should now be able to use the software.
Any particular reason why there's a need to re-activate it?
